aq 125 want pull gas to plugs
flounder67
I have an 85 AQ 125B that's firing great ;; getting gas to carb but it want pull gas to spark plugs!!! What should i check???THANKS
Grub54891
Re: aq 125 want pull gas to plugs
Not totally shure what ya mean on that one. Gas@carb,spark good.Well are ya shure its gas and not water?
A little more info would be helpfull. What have ya tried to fix it?
Grub
flounder1967
I had to reregister it wouldn't let me use my past info!! I've replace plugs, points , battery new starter had carb rebuilt!! Now gas pools under carb in the intake ! It would suck gas over to the spark plugs
flounder1967
I just checked the coil after turning engine over 3 times coil was very warm to the touch!!
Don S
Did you have spark?
flounder1967
yes plugs have spark but it's orange!! i took the carb off and there's gas puddled in the intake under the carb;;;
captmello
Maybe a compression test to make sure the timing belt hasn't slipped/broken...
flounder1967
Did check timing & timing belt all marks lined up perfect!!! This boat did set for a year due to me being sick couldn't start boat or use it!!! Could piston rings be stuck?
