I'm fixing to replace the floor in my salt water fishing boat. 3/4" marine plywood deck, polyester resin, with 1 layer 1808 biax and 2 layers 1 1/2 oz CSM. I plan to layup all three layers of glass at on time on a saturday (starting at the bow working towards the stern), then apply the gel coat on Sunday. Here are my questions....
1. the last layer of glass will be applied with layup resin. Is there any type of prep work that needs to be done before applying the gel coat?
2. I'd like to apply the gel coat with a paint roller. I've read that you want around 15 to 25 mils of thickness. Should I use a 3/4 nap roller? Has anyone done this before? Did it work good?
By the way, I don't care if the gel coat looks like orange peel, and I'd actually like it to have some texture so it's non-slip.
I appreciate any advice ya'll can give me. Thank you.
