Apologies for posting again - Info wanted on Evinrude 6 HP
Thijzzz
Apologies fot posting this message again, but within a few days the post went to the second or third page of topics, and I suspected that very few people would take a look there.<br /><br />I've just purchased an Evinrude 6 HP outboard engine, approx. 20 years old. These are the important numbers:<br /><br />Model: 69B66E<br />Serial: B037824 (Don't know if it's a zero or an "o")<br /><br />So, what information can I get now - maybe an Evinrude-website with older types-info? Or your expertise?<br /><br />I would very much like to learn more about this engine, but I´m not very technical, but willing to search and learn. Searching on the net didn´t get me much info uptill now.<br /><br />- Can anyone point me some good websites with basic outboard motor info?<br /><br />- Are there any archive-sites with manuals etc. on older engines such as mine?<br /><br />- Specific question (I searched the forum again but didn't find the answers): <br /><br />At low speed my engine starts vibrating, so I can't let the handle go: the vibrations (stuttering) cause the handle to shift even further down and the engine stops. What can be done about the shaking?<br /><br />I use basic two-stroke gasoline. Here in the Netherlands it's sold as moped-gas. Should I use another type of gasoline with separate oil, or will this do? <br /><br />Again, thanks for replies, an I'm very willing to dig into any info given, but I haven<br />'t found it on the net - yet.<br /><br />TIA,<br /><br />Matt<br />The Netherlands
oldboat1
Re: Apologies for posting again - Info wanted on Evinrude 6 HP
Hi Matt. You should run fresh 89 octane or better gasoline, mixed with marine outboard oil displaying the TCW-3 designation on the container. The mix depends on the year (can't run down the model number at the moment), but anything in the '70s or '80s would take a 50:1 mix of gas to oil. That's about 2 1/2 ounces per gallon by U.S. measures. <br /><br />Try adjusting the slow speed needle after you have introduced some new gas in the proper mix. The motor should cough and perhaps stall if the adjustment is too lean (clockwise/closed). It will stumble and stall as well if it is too rich (counterclockwise/open). Find the mid-point between those two adjustment points, and the motor should be dialed in about right. If you can't adjust the carburetor in this fashion, you may need to take it off an thoroughly clean or rebuild it.
dakotashooter2
I'm not much of a mechanic but I'll try answer some of your questions (from experience). In my experience rough idle has been from bad spark plugs and/or improper adjustment of the fuel mixture. There should be a dial/knob on the front of the motor for this adjustment. Someone more mechanically inclined posted on this same subject a few days ago and if I recall suggested closing this valve completely then open 1 1/4 turns. You then should be able to fine tune the motor while running with some further adjustment. That usually smoothes mine out. If that doesn't work the carbs probably need some cleaning or a rebuild which is beyond my skill level. There also is a tension screw located on the throttle handle that can be adjusted to keep it from slipping. As far as the fuel, I would question if the oil used is a marine rated oil(TC3) and you may want to verify the fuel mixture (50/1).
dakotashooter2
Oldboat beat me to it. :D :D :D :D
