1973Chieftain
- May 31, 2010
- 1,298
I had a Diablo Predator on my Chevy diesel which woke that engine up amazingly. Now, I have a Chevy 5.3L gas powered truck.... anyone programs or tune their gas engines with much effect?
I can't speak to what a programmer can do for a gasser but for my Cummins it made a tremendous difference (with supporting mods).
Waste of time! When I worked for Delco and worked with the engine management team at the GM proving grounds, they said there was no way an aftermarket group could know all that went into the programming of the engine management.
Thanks smokingcrater! My truck has a 6 speed auto with a manual shifting option, and either its over riding my shifting or in some other manor jumping 600 rpms frequently for no reason while towing... trying to see if a programmers might fix that problem.... VERY annoying while towing down the highway!
what kind of truck? That doesn't sound like normal, and there might be something wrong... Under warranty yet?
Anyway, I had thought your original response was more about engines... Transmissions also run their own ECU, and there ARE programmers that will target transmissions. Generally they let you set torque lockup values, shift points, shift speed, etc... They won't fix an underlying problem though, which I suspect you might have.
There are many ECU's that have been fully opened up and re-written by aftermarket hackers. (myself being one of them...) To sum it up in a nutshell, the modern ECU has two halves. One half contains the actual code that runs. This is what manages the engine and handles the day to day stuff. The other half is best thought of as a big spreadsheet or database. That is what you target for tuning, nobody cares about how the ecu does things, what is important is the data it uses to do those things. All the information has been reverse engineered from circuit diagrams, patent applications, loose lips, and brute force (computer brute force against an ECU, not the mafia variety!)
So in essence, we aren't reprogramming the ecu. We are changing everything it knows about the world though, and then just letting it do what it does best, using the factory programming. There is a certain amount of dabbling in the factory programming of course, but its only minor things.
(the obvious disclaimer, you can blow up an engine in about 3 mouse clicks... The screen shot below is just an example of a boost table. Accidentally add a couple digits in the wrong spot, and KABOOM!
Check out http://www.romraider.com/ This is a subaru specific program that i'm just listing as an example, but there are other communities out for other mfg's that are doing similar things.
Then my mileage is under 10 mpg pulling a total weight of 900 lbs!
And this is what I am talking about. The manufacturer spends hundreds of thousands of man hours setting this database up and you think you actually know more than they do? Really?The other half is best thought of as a big spreadsheet or database.
If the engineers that create this database for a living tell me not to touch it, I take their advice.
