Anyone use Easy Steer system
sutor623
I have 'crafted' my own easy steer setup, but it does not function as well as I had hoped. I'd love to steer my kicker with my main steering wheel. I was wondering if anyone has the E.Z. steer system and if they have any idea on what the price is on one of their setups. Thanks!
JimS123
Re: Anyone use Easy Steer system
No experience with the EZ Steer, as I "crafted" one myself as well. I didn't like the EZ because of the way it adjusts, nor the crappy way they mount the brackets. Too expensive as well.
I bought some SS flat stock and made brackets to mount a ball socket. One bracket mounted to the outdrive and the other to the lower cowl on the kicker. They mate with QD fittings attached to a SS rod, threaded on both ends. Trial and error till both motors are perfectly parallel.
It only works (lines up) with the kicker in the down position, and the outdrive at the top of the trim position. That gives me max steering with min drag. The only negative (if there is one) is that the rod must be removed when I'm not running the kicker.
I don't know what you mean by "not function well", but mine works like a charm.
sutor623
Well Jim I'd love to see some pics. But what I am saying by 'not functioning well' is exactly what you are describing, having to fiddle around with the motors and take the "easy steer" system off one motor or the other as to not cause issues. I guess if I want a low maintenance system I either have to buy the easy steer or spend a lot more time coming up with a prototype....
cyclops2
Banned
I used it for several years. Fantastic, simple, accurate unit, it DOES NOT SCRATCH the motors. I have a electric 30 & 9.9. SWEET setup. run either or bothat sametime. :) Disconnect the connecting rod in 10 seconds..............ALWAYS fully tilt up the 9.9 when it is NOT RUNNING....Something about WOT could push water all the way up into the stopped cylinders.
Buy it. Put the kicker on the opposite side of the boat you sit on.
JimS123
You might be over-thinking this. Its a piece of cake, no matter what your setup is. I don't have to fiddle around at all.
Use QD connections. (i.e., quick detatchable - that means no fiddling) Whether your main motor is an OB or an I/O, just drop it into position with the trim button. If you have no power trim, nothing to do.
Next, drop the kicker in the water. If you are using a bracket, just lower the bracket. If its on the transom, just tilt it down.
Finally, attach the steering rod with the QD ends - that takes all of 15 seconds.
When you're ready to stop running the kicker, take the rod off -another 15 seconds.
The initial adjustment is done on the trailer - never needs to be changed.
I realize that those 30 seconds of "fiddling" is harder than the EZS, but IMHO the EZS looks fugly.
Here are pics of the brackets with and without the rod installed. Please excuse the pic quality, and I'm sorry I couldn't get a pic showing the whole thing together but the boat is up against the back wall of the garage right now.
I built these brackets and cut the rod to fit 28 years ago and to this day I have done no maintenance on it. Both motors are aligned perfectly together and the steering is effortless. Mount the kicker on the stbd side - that way the tiller handle will be pointing in the right direction and easier to access.
sutor623
Cool man thanks for the pics!! It looks really good. What parts did you use and where can I find them? Your setup looks a ton cleaner than mine!
JimS123
Piece of 1/8" 316 SS flat sheet for the brackets. Cut to size, bend to correct angle, drill for fasteners. Use SS nuts and bolts. For the outdrive I used an existing bolt on the top
The shaft is a 3/8" 316 SS rod, cut to length, with the ends threaded.
Both came from a local industrial supplier of metals. All I used was a hammer, vise, hack saw, drill press and tap and die set.
I can't remember who I got the ends from, but it was one of the Marine supply mail order houses at the time. Just google "marine steering quick detachable ball joints" or something like that. This came up when I did it:
http://www.trmarine.com/cats/pages/auxeck.html
sutor623
K, thanks Jim, Ill send you some pics when I am all said and done. Great innovation by the way!
