anyone sucessfully changed bravo3 trim wires without removing gimble
furn1593
interested in hearing sucess stories with as much detail as possible... thanks in advance
Fun Times
Re: anyone sucessfully changed bravo3 trim wires without removing gimble
Deleted, With PM's sent.:)
Fun Times
wow, that was such an informative post.
lol, I deleted my actual answer after I know he has seen my answer already, I wanted it to be deleted after that do to the possible negativity of the actual answer.
My way isn't the right way, But it works.;):)
Don S
If you can't handle a little negativity, you shouldn't be posting in the forums.
Really sick to delete it, or even tell him to pm you for an answer.
If you want to be like that, then PM him to start with and don't even post on the forums and leave everyone hanging wondering what you said.
That is NOT how forums work.
Ayuh,... I read it,.. You're Right, it's Wrong....
It's much easier to just pull the drive, 'n do it the Right way...
The 1st time...
HT32BSX115
I did mine with the drive off (actually before I installed it) and it was pretty simple.
Regards,
Rick
furn1593
guys... I asked for detail... not banter... pm's or not.. I do not care.
furn1593
just drive off? or whole gimble.... if just drive, how did it go?
Regards,
Rick
littlebookworm
A simple recommendation: Download the manual and follow the directions given. Trying to shortcut something like that can only lead to other problems. Other than its weight, a Bravo drive is an easy pull. Start with the manual and go from there. Hy
HT32BSX115
Yeah, sorry, I meant to say with the gimbal off. I did it before putting the whole mess in. I had the gimbal lying on the floor. But it was not disassembled.
Just off the top of my head, If I was going to do it with the gimbal on the boat, I think I would pull the drive and remove the drive shaft bellows so I could just reach right in there through the "center". Of course that's a fairly big job in and of itself!
furn1593
I did it sucessfully without pulling the drive, wasnt that hard either, just need patients and the right tools.
Dshow
Will you share so other might learn?
furn1593
Tools required, 1/4"drive - 10" extension, 7/16 snapon swivel socket
step 1: have a few drinks, this one will test your patients.
Trun drive all the way to right to gain access to the bolt holding the cables in, drive in down position. Soak with penetrating oil. Easy enough to remove bolt, if you keep slipping off turn socket a little and try again. mine came out pretty easy, cant say yours will also. Disconnect wires on the inside, and yank them out.
Installation - get the orientation for the senders and their wires sorted out, and now get a coat hanger wire. push both wires up through the hole. my was easier because I have a solder connection on one of them inside the boat where it ties into the factory wire harness, and was able to cut off the push type connectors. once you get both wires into the boat take the two ends from both wires about 2" from the end and tie them together, make the knot as big as a nickle or so it wont go back thru the hole. you will need this pig tail to get the wires back into the boat easily. back out at the outdrive, pull the slack back to the knot you made out to the left side of the drive. here comes the patients part. you will need some small hands and or some long grabbing tools. get the two halves of the plug oriented with each other and tie a rubberband (tape, whatever, just on the wires though) on the inside portion of the plug. get the clamp on the wire and now use some tape to hold it in place on the wire. pull the whole thing back up into the socket very slowly while having someone watch and guild the clamp so it doesnt fall off. once its up there use you coat hanger to align the hole for the bolt. reinstall and tighten. Did the whole thing in about 3hrs by myself after dropping the clamp about 4 times. could probably do it in an hour with help. I will do my other drive once it fails or i find some senders cheap.
furn1593
Posting a follow-up - the other side failed this spring while getting the boat ready for launch. Took all of about 20min to change the senders. Heres the update, go to your local rc hobby store and get some ca glue for mounting tires, I know this sounds wierd but its made for glueing rubber - this is important. pull the wires through the transome with one of the old wires, go back an pull the wires back a little to gain access to the stopper, glue it together perfectly straight. Install the clamp plate on the wires, it will be on there snug because of the wire wrap, back in the boat and pull it tight into the hole, pull slowly and carefully, and tie it off. now back to put the bolt in with the extension and swivel socket, to me 2 tries this time but couldnt be happier with how well and fast it went. took me longer to adjust the limit and sender working alone then it did to install the senders.
