Anyone run a heater from outboard hot water?
Status
Not open for further replies.
Mark42
Was thinking of a way to add heat to a small cabin with the hot water from an outboard motor. Figured that a simple auto heater core and small fan could be used. Run 3/4 water line from outboard block to heater core, then out from heater core to a through hull out the side. Add a valve to adjust the flow to keep pressure up on the motor.
I know the water temps will only be around 100 to 120 or so, a lot less than what comes off the block in a car. But 100 degree water will provide a few BTU's in a small cabin to take the chill off on a cold day.
Anyone do anything like this? Think there is any impact to cooling the outboard?
maxum247
Re: Anyone run a heater from outboard hot water?
Don't know about the impact on your engine, but I would have to consider the distance to your cabin and I would want to insulate the line all the way to help keep the temperature up until it reached the cabin.
Don't know how well they work but heaters for cars are available, they plug into a car lighter.
SgtMaj
Removed
Removed
Removed
ondarvr
Around here many people run a hot water tank off their kickers, the water runs into a small tank (sink) so you can wash your hands or have hot water for any other need you may have. They typically have a valve to conrtol the flow and different brands need a little different setup, but it's not too hard or costly to do. I'm not too too sure how well it would work with a heat exchanger though.
Lone Duck
Master Chief Petty Officer
Hmmmm! would the water pump handle the distance. In a larger hose? What about back pressure? Why not make a small wood stove out of a 8 or 10" pipe ? Use coal or brickets like barbacue stuff. pipe outside air to it for combustin air with a gate valve to control draft ? :cool::D
tashasdaddy
Mark, i don't think it would be cost effective. there are so really great safe boat heaters available.
Ayuh,.......
I've done exactly what you're saying,......
Except it's been on I/Os.......
Btw,.......
The Heater out of a Mack R model is a Great little package for this kinda thing.......
Heater core, fan,+ minimal Venting/ Ducting....... Just run the water to it......
bosavy
i seen small heaters at pepboys that may work better. i don't think i would mess with your outboard cooling system myself
Mark42
Here is a system that is a simple auto heater core with a fan, all mounted in a nice stainless steel box. Exactly what I wanted to make. My guess is it is really intended for I/O setups, no outboards, but its worth a try. Its only about 10" wide and they claim 12,000 btu output. I'd be happy if it would blow 3000 BTU off of the outboard cooling water.
Thanks for all the input!
Z. Fullarton
Did it work? Im would like to do the same thing.....
Status
