anyone know what size and thread type the outer prop shaft nut is?
2004 searay
2000 dp-sm outdrive, i am trying to make a tool and if these threads are a pipe thread, for the inner prop, i may be in better shape than i thought.,
jimmbo
What kind of Tool are you trying to Fabricate?
You can take the Nut, to a Nut and Bolt Supply, and they can measure it
You ha e a DP. The prop nut cone threads on and has an internal lock screw. I think the internal threads are 1-1/16" and the lock screw is 5/16
2004 searay
i was hoping i oould fabricate a tool to resemble the inner shaft puller tool. 1742921322383.png1742921322383.png
You know the inner and outer shafts come out as an assembly prior to separating them.
2004 searay
no, i didnt. from what i read, that tool screws onto the outer shaft and you use a bolt through the center of the tool to tighten against the inner shaft which pulls the outer shaft and carrier from the case. no?1743004985665.png
  • 466777-Volvo_Penta_Stern_Drive_SX-M_DP-S_Models.pdf
