Anyone know this part name or number?
3ball
Is there a downloadable version of a parts catalog? I am trying to find a part number and cant find it anywhere. The Mercruiser manual lists it as a check valve in the cooling system section. Its a plastic oval shaped & is on a port-side cooling hose with a "float type" valve. I did a search for "Mercruiser check valve" & came up with nothing.
Engine is 5.7 MPI. serial Number M320848
ken_23434
Re: Anyone know this part name or number?
Check out https://www.mercruiserparts.com/mercruiser_parts.asp
That sight has online schematics of the engines and drives with names and part numbers. You can select the part and order it from them, or like I do get the name and part number so I can get it from the local guy.
Click on the button that says "Search with Pictures", then you will go through a couple more screens where you identify what engine/drive, year range etc...
3ball
Thanks Ken that's what I needed
