Anyone had these problems???
warden1975
I have a 2005 Larson 228 LXI with the 5.7L engine. Recently both of my docking lights stopped working. Is there a certain fuse I can check for that? I've heard that if one goes out the other one might not work? I thought I was done with X-mas lights...
Also my outdrive dashboard indicator only registers when the outdrive is either all the way down, or all the way up. It doesn't work when it's in the middle. Any suggestions or ideas for either problem would help me out. Thanks!
mrbignellie
Re: Anyone had these problems???
In regards to the docking lights, I had the port one go out last year and the other still worked. Pretty simple fix, just had to get a new bulb at the local hardware store and took about 10 min. In regards to the gauge, I had a problem with my fuel gauge last summer and it turned out to just be a loose connection behind the dash. Both minor fixes. No other issues since. Hope this helps.
