Re: Anyone ever made thier own seacast...
I started with a good resin, added Cabosil, milled fibers of different lengths and some micro ballons. The ratio of these products may change for different types of uses and how you plan to apply it, more resin if you want it flow, less if you want it to hold it's shape. Plus there are different types of catalysts, for thin areas the normal catalyst you can easily buy works well, for thicker build ups you can get blended catalysts that will not get nearly as hot, these aren't easy to get unless you go to a fiberglass specialty store and special order it. The better the resin and the more glass fiber you add, the stronger it will be, VE works very well, but ISO resin can be used with good results also.
