Any tips on a Mercruiser/OMC 120 engine rebuild?
wrfalpacas
Ok, So I have 2 engines, a 68 2.5L mercruiser and a 71 2.5L OMC. The mercruiser has a welded crack repair in the block, and smokes. The OMC is what I was going to replace it with.
Question 1: Do I need to get a reman head with hardened valves and seats for unleaded gas or have the head redone?
Question 2: Are the engines interchangeable, or are there problems with a direct swap?
Question 3: While the engine is out, are there any easy mods I can do to get a little more horsepower?
Question 4: Is an electronic ignition system a good investment for this engine?
Question 5: Are there any differences in the accessories such as fuel pump, that are better on one brand vs the other?
Thanks in advance!
IVAZ
Master Chief Petty Officer
Re: Any tips on a Mercruiser/OMC 120 engine rebuild?
1- If the head you?re going to use is in good shape you can leave it alone. Some guys use lead additive. Others just run it with regular unleaded.
2- They should be interchangeable.
3- I don?t know of any upgrades. It?s probably best to get it running before you start digging into it, unless you are really sure of what you?re doing.
4- Again, I would get it running before I started changing the way it was set up to run.
5- Keep all the Merc accessories with the Merc. Swap them to the donor engine.
Fishermark
Not necessary. If the head is good, then go with it.
Direct swap.
The only easy "mod" would be to replace it with a 3 liter - still a direct swap, but with more horsepower.
I think it is a good idea - I know others disagree. But the electronic ignition gives a more reliable and steady performance.
Don't know
