Any problem going from 150 to 200HP
nelsonsoft
I have a 1980 18' low profile baker boat with a 150HP Evinrude. I'd like to go to a 200HP. While it is rated for a 150 does anyone see a problem pushing it to 200HP? Also if I exceed the HP rating will shops not install this because it is exceeding the rating? Before I buy a motor I want to make sure I can get it installed.<br /><br />Thanks,<br />Gil
nelsonsoft
Re: Any problem going from 150 to 200HP
Thanks for the honest reply. Perhaps I'll just upgrade to a newer 150. By the way I believe I have a 20" shaft. I measured from the base of the engine to where the lower unit splits. What effect would a 24" shaft have? <br /><br />Thanks again,
