any known issues with 1992 mercruiser 5.7
blenkch
What should cylinder compression be.
Thanks to those who steered me away from the cobra 350 yesterday...
Fishermark
Re: any known issues with 1992 mercruiser 5.7
A 5.7 (350) doesn't care if it is in a Mercruiser or an OMC package. The basic engine is the same. It is a great engine. Look at the basics like compression, etc. Are you buying a boat? Or an engine? There's a lot more to looking at a boat than just the engine.
John_S
A 5.7 (350) is probably as bullet proof as they come. You would have an alpha (gen I?) or a version of the bravo drive. They have good part and repair support.
Compression should be within 10% on all cylinders. Probably psi readings of 150 or above.
BIGALF
it's 19 years old!!!
blenkch
Bought a 1992 24 ft 'Thundercraft express with a 5.7 Merc. Compression varied between 135 and 145 warm. Only 816 hours.
Wondering what the very best prop would be.Had a 17 pitch with vortex but thinking may be wrong as still a bit sluggish to get out of water...
Ayuh,... Those numbers ain't too bad...
For yer prop questions, go to the prop forum, 'n read the stickies pinned at the top for the required Info...
