Any iguana keepers?
ob
Halloween afternoon I captured a 3 ft. 5 pound Mexican iguana in the backyard.I suspect it is either an escaped or released pet of someones.No luck locating anyone that is missing one as of yet.My daughter wants us to keep it,so after reading up a bit we constructed a cage that is 6ft tall X 30" deep X 4 ft. wide wuth a 24" X 6 ft access door.Created 3 levels within cage and a mesquite branch that runs from the bottom of cage to the top with two semi-horizontal resting branches.Cage top is also 1" mesh and we placed a 24" ZooMed 5.0 repti-sun light fixture that allows the iggy to get within 10" of.So far we have fed him hibiscus leaves and flowers plucked from the garden which he graciously gobbled up.It doesn't like to be approached and picked up and has all of the social graces of an axe murderer.I don't really care to handle him much anyway.We also plan on placing a three inch deep water tub in the bottom of its enclosure so that he or she can get wet whenever it chooses.Any other dietary tips from any of you ladies and gents that may be lizzard lovers is much appreciated.Also any other habitat suggestions is apprecitaed .From some of the literature we have come accross it seems that the artificial sunlight fixture will only supply the iguana with some of its required UV rays and that whenever possible that it should recieve some unfiltered direct sun to aid in its metabolizing needs.Thanks much for any input.
mattttt25
Re: Any iguana keepers?
i had an iguana once, didn't care for him much and he ended up back at the pet store. sounds like you've done ok so far. i always fed mine kale and other green veggies. give him plenty of fresh water daily, and keep the light on. watch the tail, they whip pretty hard.
CalicoKid
I had one up until a few years ago, reached 3 1/2 feet. They can live a long time and learn some funny things along the way. <br /><br />Dark leafy veggies are important. You may need a mineral suppliment powder or special supplimental food to supply it with the nutrients it needs. None of this was too expensive when I had mine. Kaytee makes a dry food that they will nibble on which provides a lot of the elements they need. Iguanas will always eat the fresh stuff greedily. Don't feed them head lettuce, it's all water and no nutritional value, don't eat it yourself either... My Iguana loved to eat bananas, grapes, oranges, bitter greens, bell peppers, broccoli leaves, shredded carrots (really improved his color). Give them variety, hand feeding will improve his or her socialization quite a bit. Feed him a whole peeled banana for a good laugh!<br /><br />Your cage sounds ideal for an Iguana, they like to climb up and down during the day, that is their daily routine involves time spent at different levels of thier "jungle" depending on temp., light, feeding, etc. I put a couple of large branches and synthetic sisal ropes for him to climb around and bask on. Avoid cedar or pine chips or branches, the resin and its evaporates are not good for lizards.<br /><br />Put the lights on a timer, routine is important. Try to locate an electric heated stone, my iguana always spread out on his after meals (to aid digestion) and on colder evenings.<br /><br />I located my cage so that it got AM sun through a window for a couple of hours each day. The sunbeam didn't flood the cage though, just hit half of it and left half shaded. The lizard moved in and out of the sun as he preferred. This seemed ideal to me.<br /><br />Iguanas will not remain healthy unless they have humidity, If you are in a dry area you will need to provide moisture. I covered the screens on my cage with clear plastic in winter to conserve moisture and heat. Iguana's need fresh drinking water at all times!! I also had a tub with about 3" of water in the bottom of the cage. My Iguana usually used it for a toilet which made cleanup easy (flush!). <br /><br />I'm sure you know by now, Iguana dung is NASTY, half bird, half cow manure! I cut several sheets of vinyl to fit the bottom of the cage that I could spray off or toss to ease cage cleaning. Don't use sand or sawdust, he'll try to eat it and mess up his mouth and crop. Avoid plastic plants for the same reason.<br /><br />Iguanas are a little fragile so if you're afraid you'll hurt it in a struggle then you should maybe not handle it. Mine was not afraid of me but reacted voilently to constraint. After reading that letting them go just reinforces the struggling behavior I started picking mine up everyday and holding it until it stopped struggling and for a while after then letting it go once it calmed down. After a while I was able to handle him whenever I needed to. Of course he was pretty small when I got him... Reptiles can harbor bacteria, that's natural, always was your hands after handling or feeding, be careful about being bitten. You can trim an Iguana's claws much like a cat's, clip off the sharp tips but don't cut into the darker growing part.<br /><br />Of all Lizards Iguanas must be the most sociable and easiest to keep as pets. They are pretty easy to please as long as they are healthy and not in a corner being ignored. They need stimulation whether you handle them, hand feed them or just sit at the cage door and talk or whistle (good socialization is to have your phone conversations in front of the cage). They do require daily attention in captivity and will thrive if treated right. Mine would actually follow me around a room if I let him loose and on a few occasions escaped his cage in the morning and crawled into bed with my wife and I!! I'm sure he was seeking warmth or food and not companionship but who knows?<br /><br />Good luck with the new friend! What's his/her name?
FSHKPR
Ensign
I have had a couple. they are a fun pet and i thought pretty easy to keep. Lots of fresh fruits and vegatables and there is an igauna dried food out that i kept in the cage at all times. also i used a powdered vitamin that went in to the drinking water. the last on got to be about 3 foot long when i donated him to a school. dont worry if you make a grab for him and only catch his tail. after it breaks off it will grow back. speaking from experience. agree with everything calico said. take him out and handle every day, or they will get skittish. and they need the socializing. also would like to hear what you named him. my last ones name was Gizmo.
jinx
Lay off the iceberg lettuce, there is not enough food value. Romaine is better. Spinach, I have read has too much something or other in it for it to be healthy.<br /><br />Some vets recommend a bit of dry dog food, but not cat food. <br /><br />As for the sex of the beast, it is difficult for even an expert to tell, unless, of course, you are another iguana.<br /><br />Jinx
ob
Thanks for all you guys input.It is very helpful.This lizzard must have been living in the mesquite woods behind our propertry for some time as he seems partial(at least for now ) of the Hibiscus leaves and flowers ,prickly pears off of the wild cactus plants ,grapes,and pretty much turns his nose up to all of the other things he's been offered.Including okra,bell peppers,bananas,collard greens,shredded carrots and the like.Maybe in time.I didn't want to spoil him on just what he wanted but at the same time wanted him to at least eat.He's actually calmed down quite a bit and will allow (if slowly approached)being scratched on the side and under his chin.He's quite the character.My daughter named him (it) Spook,since he was found Halloween day.I'll post some updates of how he's adjusting to his new home from time to time.Again ,thanks for all the info,I'll keep trying other foods and follow the good advice.
Scoop
Ob, sounds cool. I don't know anything about Iguanas other than I have seen a lot fo pet stores feed the broccoli chunks. When my son had soem anoles, the books said to give most lizards supplement powder because they lose calcium and it affects their joints. It sounds like you got soem good advice. There should also be some good books out there. Have fun.
oddjob
They taste like chicken! <br /><br />And there everywhere down here in S. Fla. I've seen as many as 10-12 on the side of the road in Davie, Fl....at the same time grazing like cattle! Almost ran off the road one day in Hialeah after spoting one about 5-6 foot long eating something by the side of the road. It looked like the new Godzilla movie! :eek: <br /><br />In Trinidad they hunt them for food and sport. :p <br />....the other white meat...he,he!
FSHKPR
Ensign
yeah i heard they are actually pretty tasty too! when i called my buddy about accidently tearing the tail off mine he told me dont worry about it it will grow back and to just skin it and fry it up butter. now i am usually open to trying anything new to eat but i just couldnt do it. took a while but the tail did grow back. little lighter color. :D
