Any idea what would cause this?
Z3bass
I was out yesterday afternoon and my motor (2002 Evenrude 225 Ficht) started bogging down when trying to get on plain. Later on in the day it started grinding when cranking. Got it started, ran fine for about 15 min as I headed back to the marina and it stalled going through a 5 mph zone. After that I could not get it started again, it went from a grinding sound with the motor trying to turn over to just a spinning noise coming from under the cowling. Pulled the cowling off and this is what I found! Any ideas as to what would cause this (picture attached)?
joeanna
looks and sounds like the starter gear stayed up in the flywheel teeth and after spinning it seized up?
boobie
Looks like the starter got engaged when the motor was running at higher rpm.
Z3bass
Any idea what would cause that to happen? Defective starter?
interalian
Well, you have two problems, bogging/stalling and the broken starter. Are the starter mounting bolts tight? If they got loose it may explain the grinding sound, and possibly once started after the grinding caused the gear to stay meshed to the flywheel.
Grub54891
Could be a stuck solenoid, or a short in the start circuit, or a bad ignition switch.
