Re: Any good tips for a noob to trolling?
....the release is attached to the cable somewhat above the weight, and that many of you will attach spinner attractors to the weight itself....far behind the release is the lure positioned?......Does the release have the capability to adjust for release tension? Seems like depending on what I am fishing for I probably want to change the release force......Here's a weird question... I know some folks use trolling plates to get the speed down and the RPMs up a bit. Is it possible to troll and slow the boat by draggin a drift sock rather than using a plate? Or is that just asking for trouble WRT the motor and landing fish? Seems like directional control would be better.....I've got an ok depth / fish finder, but am debating attaching the transducer to the stern. I am almost thinking that I want to put it on a rod that I can drop off of the bow, or out the side. Or does a stern mount transducer at trolling speeds work ok? (worried about boat turbulence).....I have two daughters as well. My oldest can care less about fishing. My youngest loves to fish and wants to hunt this year. She and I went on a Canada fishing trip last year and had a blast.
1] I don't use flashers off the cannonball, but my fishing buddy does. From my boat. We both catch fish, and until he starts catching more than my side of the boat, I probably won't
2] The lure is positioned close sometimes, further others. Walleye don't seem to like the cannonball, so I run long leads. Salmon and Lake Trout seem to like checking out my fish-shaped weight; I set about 4-to-8 feet back for them, usually about 6 feet.
3] The Chamberlain Release is extremely adjustable, and consistently more so than other releases. You can set it light to trip for a 6" perch; then you don't wind up dragging a useless lure around for a 1/2 hour wondering why you aren't hooking up with anything. Or you can increase the pull to handle cowbells or other heavy-pull terminal gear and lures.
4] Trolling plates are fine- not for running higher RPM but for letting the main engine (which will likely be propped such that you get 2.7-3.5mph or more at an idle in gear) act as a troller. But a drift sock is probably more controllable (than a plate) and lets you maneuver quite precisely off its pivot point. PLUS if you need to slow a drift in a breeze, it can do that too. Pros use socks and their trolling motor(s) to precisely cover a breakline or whatever. Many times these are tied off the bow, so no issue with the motor unless you do something really dumb
You might want to consider a five gallon pail or two with a rope on them for a lowbuck approach.
4.5] I use a bracket which connects the transom mount 44# Minnkota to my 40hp main engine. Then I can steer from the helm. BIG improvement. The electric troller is quiet, and the main engine acts as a rudder. We bias the electric (which is on the port side) to push a straight line when the main engine is straight ahead. A little loss of efficiency, but a gazillion times less attention to go straight and turn.
4.6] The 44# thrust electric is just about enough on my 14' Niagara. Not enough in a 15 knot breeze if it's not to your stern. But even in calmer conditions, I think a bigger electric would be better, ESPECIALLY on a 16' like you have.
5] you don't want the transducer any other place than at the stern. Transom mount is fine if you follow the instructions; use 5200 to seal the screws. Or a shoot-through application, but transom mount works great and will do you fine at ANY speed. Up front and you won't be able to get a reading at speed. A second sonar can be mounted up front if you have a forward fishing deck by using a trolling motor mount. That only works when the bowmount trolling motor is deployed, but no one should be up there when you are running above a troll anyway- not safe.
My older daughter used to ice fish and stuff with me and then... well the years go by, she got older (now 18), and lost interest. Then again I go fishing all day when I go...:redface: maybe I spoiled her. The younger (now 14) likes to go fishing, but for short periods. Plus she is very hard to convince to go fishing- but once she agrees to she's into it. Until I mention that she is enjoying it which is an almost immediate cue to become "bored." Personality thing...
Hope this helps,
Mark
