Any electricians in the house?
dolluper
Re: Any electricians in the house?
Not positive on your state codes but up here if you run wire over a 80 feet the requirements are for a larger wire guage like #4 verses smaller #6 for under 80 feet, so check your code plus the larger wire will give you more amps<br />-----#10=30amp load at 240 volts<br />------#8=40amp load at 240 volts
