HIT 4400 (up 300) at WOT Trimmed up for speed at 35 mph maxed out...lowest plain was 12 mph at 2400 RPM. 22 MPH At 3000 RPM cruising speed. ..How do those numbers look?.
Off....
My 140HP 3.0L with a 1.98 ratio drive and an 18P 4-blade prop is turning almost those exact same numbers. Didn't you have a 4.3L, which should be a 1.81 (?) ratio drive? Also, is the MPH by GPS or the boat's speedo?
