Any clue what this gunk is?
Dmknox98
Any idea what all this white oily foam is? Anything I should be concerned about?
Honorary Supreme Mariner
Fairly normal for a 2 stroke after idling.-----Any water getting into the gearcase?----Thermostat installed and working properly.
Crosbyman
looks like emulsified gear oil to me ..pressure test the gc pull prop check for birdnest
tjandrews
Doubt that gear oil would find it's way up into the exhaust housing.
It could do it if the shift rod and/or bushing are worn badly enough, or if the sealing o-ring is broken.
I have a '56 15hp that looks even worse. Needs a shift rod, probably the bushing as well. You can feel the difference as you slide the o-ring onto it, tight at first, loose when in place.
tjandrews
Looks to me like that's one of the units that has a gasket under the water pump seal. I would think that if that gasket is bad, gear oil could leak around it.
saltchuckmatt
Best to do what Racer says especially with the older ones. Much more likely water gets in than oil getting out the top.
What is your gas to oil ratio on that old girl?
Chris1956
Gee, smell the stuff. If it is gear oil, it will stink from the sulfur in it. If it is 2 cycle oil, it will smell like gas or oil.
Jeff J
If water can get in then oil can come out, especially if there is enough water is getting in to push the oil out. I pulled a gear case a couple of years ago because of an oil slick in the slip. The gear case had way more water in it than oil and was floating oil out a bad seal on a top fill plug.
Dmknox98
I changed the gear oil out and have checked it a few times after use and haven't seen any milky white in the oil. I'll have to check the thermostat but I haven't had any issues with it overheating so far.
Dmknox98
It's 24:1, but I'm sure there's a little more oil in than strictly neccessary.
Dmknox98
Thanks, I'll check the shift rod again. It looked pretty good when I pulled it out but I wasn't really focused on it.
You were installing a new impeller in this 6 / 9.5 / 10 HP ?----What ratio gas oil mix?-----Model # of this motor?
Berdink
I think I've gotten that gunk when I idled in a barrel too long.
Is that what that motor calls for?
Unless you have a vintage Johnson, I would think you should be closer to 50:1 - That would be less ounces of oil per gallon than what you are mixing at 24:1. 24:1 seems like way too much oil per gallon of gas.
The issue is perhaps the thermostat missing or stuck open.---Help yourself and post model # here !----I can not see / look over your motor.
