Antifreeze out of sterndrive
langford7
Hey everyone, I have a 1984 Del Magic with the 470 in it. I know, I know, the 470. But anyway, when I put antifreeze in the motor it come out of the sterndrive where the raw water enters. So I took the lower end of the stern off and the propeller housing where the pipe goes up to the top end was melted. I also took the pump apart and the propeller was bad. Would that let engine coolant in to the stern or is it a bad heat exchanger? Any help would great.
Thanks,
Billy
achris
More fish than mountain goat
Re: Antifreeze out of sterndrive
Ok... your engine has been overheated.. That's why the plastic water pocket cover is melted. That needs to be replaced. The anti-freeze coming out indicates that you also have communication between the freshwater cooling and the seawater cooling. This could happen in the heat exchanger, or you could have a head problem, cracked, or leaking gasket.
Chris............
