1977 SILVERLINE
Thread starter- Joined
- Jul 11, 2011
- 113
As the title says my 1977 470 is leaking antifreeze out of the raw water pickup of the mc 1 outdrive. This 470 has the closed cooling system. I'm not sure but I believe the heat exchanger is probably leaking? I pulled the drain plug on the heat exchanger for the fresh water side and antifreeze also ran out of the drain. Just wondering if the heat exchanger is bad or is there any other possibilities? Thanks!
