Re: Antifouling Paint on Props?
hey H2O,<br /><br />if your using the boat frequently i wouldn't do the shafts for the reasons i mentioned. as a mechanic i hate having to scrape b-paint off shafts when doing work on em. most guys i work on with inboards just clean up the shafts in the spring a little if they get anything on them. like i said, if your concerned, you could just spray the shafts, just avoid getting heavy buildups of paint on them over time. make sure they are zinced properly also.<br /><br />not that i do a ton of detailing anymore, but generally i like to see them cleaned up with either a Finesse or even a one step cleaner/wax (the Maguires is nice) after a wash, then a good carnuba wax on top. 3M makes a real nice premium wax that comes in a little black jug, Maguires makes nice products also.. you can just wash and use the good wax, but obviously a slight polish with the Finesse (3M) or a cleaner wax prior will do a nicer job.. <br /><br />as far as wax procedure, cleaner/wax can be done with a buffer, good wool or foam pad, or it can be done by hand with a wax pad. when i ran a detailing outfit it was a combination of both, by hand for tight areas and a wheel for larger expanses, such as hulls, etc... when wheeling, buff the area thoroughly till covered, spur your pad and slow speed remove the haze/film after it dries..<br /><br />also for washing, a light car wash is best, the blue stuff. do not use detergent or things like that..<br /><br />how big of a boat is this?
