Searay87
Thread starter- Joined
- Sep 10, 2009
- 106
This is my first attempt at winterizing. My question has to do with making sure the anti-freeze works its way into the sea water intake in the outdrive. Will gravity look after this? I'm guessing the answer is yes but it gets mighty cold in these parts and I don't want to take a chance on having a pocket of water anywhere in my cooling system.
The Mercruiser instruction manual for the 3.0L 4 cylinder GM enine says to pour anti-freeze in through the thermostat housing to fill the block and head. It also says to remove the 1" hose to the exhaust manifold and fill it with anti-freeze. Do I need to have someone watch the outdrive to until the anti-freeze pours out the raw water intake? I've attached the cooling system flow diagram.
Thanks,
Bob
Thanks,
Bob
