I just replaced the water pump on my 1991 150hp Mariner. Since it hadn't been touched in 5 years, I replaced everything- impeller, base and housing. I even put an air test on the lower unit which held 10 psi for 10hrs. It seems as though I get very little water flow at the tell-tale when idling once the tstats open.When I increase rpm, the water stream increases as well. This all appears correct but I am a little concerned because it seems as though the stream at idle is less than before I replaced everything.
Is there something that I could have messed up on? I made sure all parts were OEM and matched what I removed when reassembling. There was some silicon caulk around the outside of the old base. Should I have used a gasket sealer when assembling? If there is a little water leaking around the base(not into the lower unit though) would it cause a problem such as loss of pressure? I took it all apart again and couldn't find anything that was obviously wrong.
Thanks for any info
Larry
Thanks for any info
Larry
