Silvertip
- Sep 22, 2003
- 28,771
Re: Another transom saver question
The transom is supported from below by the bunks or rollers so it isn't the vertical forces that damage a transom. It's the rotational forces that you are trying to eliminate. Mounting the transom saver to the hull does absolutely nothing except increase the probability that damage will occur. If the boat is moving around on the trailer it is not secured -- thats why stern tie-downs should be used. With the boat secured, the transom saver attached to the trailer frame, everything is tied together and the trailer springs are absorbing the rotational shock loads.
