Re: Another Smart Tab Question (placement)
Brad, your best bet is to contact nauticus by phone. They will probably want you to send them a picture of the transom if they already don't know your model of boat. Get them to tell you exactly where they need to be mounted. If you go by what others have done, it may not be correct. These have to be mounted correctly or you will not get the performance intended from them.
The chime is the flat spot you see from the very outside of the hull inward about 3 to 4 inches. Normally on a flat/straight transom the tabs would be mounted right next to these or 3 to 4 inches in from each hull side.
The first picture you posted looks correct to me, because they are mounted 3 to 4 inches inward, right next to the chines. You want the tabs to be on the angle part of the hull. Again, contact nauticus so you are drilling once!! Good luck.
