Mechanicalmike08
Thread starter- Joined
- Aug 29, 2018
- 308
So I bought this boat at the end of last year and only got to use it 2-3 times. Then spent all winter rebuilding it. It's a 95 Larson 174sei, factory specs say 1800lbs. 3.0 with what I assume is the recommended 1.92 ratio gears. It currently has a 14.5"x19 3 blade aluminum quicksilver prop.
The few times I took it out last year and I just had it out for memorial day it seems to be lacking in top end. Barely over 30mph. I just switched to a GPS speedo. I unfortunately do not have wot rpms at the moment. We generally just run around, may pull a tube once in a while. 2-4 people usually.
I guess I'm curious if that seems like a common prop for this size boat, its looks really new and I'm curious if the previous owner just went and bought what he could. Also will say she seems to steer pretty lose at low speeds. Any help would be great.
