another oil question
OLDSPUD
I have dropped a chev 400 sm-block into an old chev '61 pickup, now it is time to change the oil. I'm thinking I should use a non syn straight 30 oil, woiuld love to use a synthetic or syn-blend.<br /><br />Comments anyone? <br /><br />Should I use a multi weight, and can I use synthetic?<br /><br />Oh ya, the year of the motor, I think is about a '77 or'78.<br />Thanks
Re: another oil question
Is this a New Rebuild motor,..... Or an Exchange motor,..???.....<br /><br />What's the History on this 400,..???......<br /><br /><br />"I'm thinking I should use a non syn straight 30 oil,"<br /><br />Why would you Think That,..???......
ZmOz
Straight 30 weight oil has been obsolete for at least 30 years. Large peices of American iron like 10w30, 10w40, or 15w40 depending on your useage.
20/20
Originally posted by ZmOz:<br /> Straight 30 weight oil has been obsolete for at least 30 years.
???confused??? I'm a little lost on this one, I buy 30weight for my tractor car lawn mower snow blower old jeep etc etc etc from wal-crap on a regular basis???? A mech friend of mine uses nothing but 30weight on his older engines?
LubeDude
ZmOz is pretty right on with his statement, however in a mild climate its not a problem. However, Utah sees its share of cold weather. A 10W-30 will do ya fine in the winter months, and if you tow or use the truck hard you might concider a 15W-40 Diesel oil in the summer months. If this is a new engine, I would say you could use a 10W-40 all year around in a synthetic of your choice.
ZmOz
Originally posted by 20/20:<br />I buy 30weight for my tractor car lawn mower snow blower old jeep etc etc etc from wal-crap on a regular basis????
If you look in any manual for those peices of equipment that has been updated within the last 10 years you will see they recommend multi weight oils. Briggs and Stratton, for example, listed straight 30 oil for all their engines for a very long time. Go to their website now and you'll see they recommend 10w30. 30 weight will work ok in some climates, but multi weight oils will work even better in all climates.<br /><br />
Originally posted by 20/20:<br />A mech friend of mine uses nothing but 30weight on his older engines?
Some of the worst advise I've ever heard has come from mechanics...especially concerning oil.
20/20
Originally posted by ZmOz:<br />If you look in any manual for those peices of equipment that has been updated within the last 10 years you will see they recommend multi weight oils. Briggs and Stratton, for example, listed straight 30 oil for all their engines for a very long time. Go to their website now and you'll see they recommend 10w30. 30 weight will work ok in some climates, but multi weight oils will work even better in all climates.
I understand what you are saying, but when an engine gets older and has wear the straight 30 can be much better then the 10w30. Like I said I use it on all of my engines that have hrs on them. I also use it on egines that are going to be working hard. NEVER once have I had a problem, if anything I believe it adds{or prolongs} life. Maybe this is because I keep up with regular oil changes cleaning etc???? Oh and aren't we talking about an older V8 not a new briggs & stratton? <br /><br />
:eek: And some of the worse advise I've seen as come from the net. The mech that I am speaking of is VERY highly respected and has built many engines. He works on the state troopers, fire ambulance, modified trucks etc... plus regular folks. He has a waiting list a mile long and never has slack time, he also works many sundays just to keep up. <br /> <br /> With all of that said I have also met a few old timers that said they never change there oil. One guy had close to 200,000 on his car and not once has he ever changed the oil{said changing oil causes problems} :confused: I quess it comes down to opinion care and in some cases maybe just plain luck ;)
LubeDude
Originally posted by 20/20:<br />but when an engine gets older and has wear the straight 30 can be much better then the 10w30.
BS: :confused: <br /><br /> The only difference in a 10W30 and straight 30W is that when cranking cold, you are cranking with a 10W. With the 30W, when cranking cold you are cranking a 30W. When warm, they are the same. :rolleyes:
OLDSPUD
You all have confirmed what I have been told by mechanics and others, that is why I asked the question to begin with.<br /><br />The motor leaks just a little, I did not rebuild it, everything checked out when I got it comp ratio and so forth. I didn't reallize it had a small oil leak, so that is why I asked about the synthetic oil. I've been told that it may make it leak worse.<br /><br />I put valvoline syn blend 10-30 in it. I will watch to see if the leak gets worse.<br /><br />Spud
ZmOz
If you switch to a 40 weight, it might slow or even stop the leak. My old Jeep leaked about a quart every 50 miles with 10w30, but with 15w40 it only leaked a quart every 150 miles or so. :D
heycods
But on the other hand, My john deere 4440 is a 1980 year mod, it has 7300hrs on it,compression is perfect, did underhaul last year just for safetys sake, changed injectors and reworked injector pump, it has had 30 wt oil ran in it since brand new, I aint about to change now.<br />Johndeere specifys 10w 40 but the specs only changed 5 years ago.
20/20
Originally posted by Bassin' Fever AKA ]BS: :confused: <br /><br /> The only difference in a 10W30 and straight 30W is that when cranking cold, you are cranking with a 10W. With the 30W, when cranking cold you are cranking a 30W. When warm, they are the same. :rolleyes:
My point is that the 10w30 has a much better chance of breaking down, while the straight 30 will hold its viscosity longer. In an OLDER engine with wear straight 30 is better. You are correct when it's cold the 10 indicates that the oil is 10, once warmed up it will change to 30. My concern is with the additives that are added THEY DO cause the oil to break down at an earlier age. With an engine that is older or is going to be working harder this could cause a problem. Do some research :rolleyes: .
20/20
Originally posted by ZmOz:<br /> If you switch to a 40 weight, it might slow or even stop the leak. My old Jeep leaked about a quart every 50 miles with 10w30, but with 15w40 it only leaked a quart every 150 miles or so. :D
Or a person could fix the leak :) Ooops with all the pro help here I quess that's not an option :D
20/20
Originally posted by heycods:<br /> But on the other hand, My john deere 4440 is a 1980 year mod, it has 7300hrs on it,compression is perfect, did underhaul last year just for safetys sake, changed injectors and reworked injector pump, it has had 30 wt oil ran in it since brand new, I aint about to change now.<br />Johndeere specifys 10w 40 but the specs only changed 5 years ago.
MY point exactly I have a 1948 allis chalmers never been rebuilt{well taken care of} The records that have been kept with it over the years say it has only ever had straight 30. Runs better then the new boys out there. Also have a 48 willys with a 71 straight 6{ford engine} in it use nothing but 30 and it runs like a bear in a honey room.
ZmOz
Originally posted by 20/20:<br />My point is that the 10w30 has a much better chance of breaking down, while the straight 30 will hold its viscosity longer.
If the 10w30 breaks down then you already should have changed the oil a long time ago. Whether an engine is old or new makes no difference in how hard that engine is working. B&S recommends 10w30 for all their engines, new and old. They would not recommend it if there was a problem with it breaking down. I have a 2.5hp B&S engine built in 1960 that easily has thousands of hours on it. I feed it Amsoil 10w30 and it runs beautifully.
LubeDude
Originally posted by 20/20:<br /> Do some research :rolleyes: .
:eek: Ha, Ha, Ha, Ha, Ha, Ha, Ha, Ha, Ha, Ha, Ha, :eek: <br /><br />Guess he has no Idea who he is talking to!!! :confused: <br /><br />Your statement is sort of true, but unless you are trying to go 10,000 miles between changes, breakdown isnt going to happen on a 10W-30. A 10W40 maybe, but not a 10W-30. Its the spread you need to be carefull about.
TheOilDoc
Originally posted by ZmOz:<br /><br />Straight 30 weight oil has been obsolete for at least 30 years.
SAE 30 is alive and well. It is particularly popular in industrial, marine, diesel, and heavy-duty applications where multi-viscosity oils are more prone to breaking down. Mulit-viscosity oils are popular because of the large number of different automotive applications and climates that they must be used in. <br /><br /><br />
Originally posted by Bassin' Fever AKA LubeDude:<br /> <br />The only difference in a 10W30 and straight 30W is that when cranking cold, you are cranking with a 10W. With the 30W, when cranking cold you are cranking a 30W. When warm, they are the same.
Not quite. When they are both warm the 10W-30 still has viscosity improvers in it that distract from the oils ability to withstand high shear and thermal stress. Most SAE 30 oils will maintain higher viscosities longer when compared to similar 10W-30 oils. <br /><br /><br />
Origianlly posted by ZmOz:<br /><br />If the 10w30 breaks down then you already should have changed the oil a long time ago.
Not necessarily. An engine, particularly an older engine, can present situations early on in the oil's life where multi-viscosity oils break down prior to a mono-viscosity oil.<br /><br />Spud21, the advantage of multi-vis oils are that they can be used in a variety of engines and climates. If you're interested in a straight 30, you might want to look at a synthetic SAE 30. I have had great success with Royal Purple SAE 30. <br /><br />'61 Chev with a 400. Nice. :)
LubeDude
Originally posted by TheOilDoc:<br />I have had great success with Royal Purple SAE 30. <br /><br />'61 Chev with a 400. Nice. :)
:cool: Great oil! ;)
20/20
TheOilDoc;<br /> <br /> Thank you sir, you did a much better job explaining then I did. <br /> <br />
Originally posted by Bassin' Fever AKA LubeDude:<br /> <br /><br />Guess he has no Idea who he is talking to!!! :confused:
Maybe I should roll out the red carpet before I post a debate with you ???? Sorry, excuse me if I'm in the way of your ego.....
20/20
Originally posted by ZmOz:<br />If the 10w30 breaks down then you already should have changed the oil a long time ago. Whether an engine is old or new makes no difference in how hard that engine is working. B&S recommends 10w30 for all their engines, new and old. They would not recommend it if there was a problem with it breaking down. I have a 2.5hp B&S engine built in 1960 that easily has thousands of hours on it. I feed it Amsoil 10w30 and it runs beautifully.
Well comparing a 2.5 single cylinder engine too a V8 is one thing that should be taken into consideration. Would that 2.5 pull a horse trailer, large boat or even a 6,000lb camper up steep hills? Probably not, so would there be a difference in how the oils would break down, probably so. I agree 10w30 probably would be fine, regular changes etc... I'm just pointing out why settle for pennys when you could have quarters?
