Another Oil Leak Question (BP North)
brian6464
I have a 50 hp 4 stroke Evinrude. It was winterized and tuned at a dealer last fall. I stored it shrinkwrapped outside on my property during the winter months. When I put it in the water last weekend....there were no noticeable leaks until I tried to start it. Then, there was what seemed like significant oil loss. I pulled the prop and it is pooled up in the lower gear case behind the propellor. It seems like it only happened when I tried starting it since the propellor was in the water for a day with no noticeable oil. There was also no oil on the ground where I stored it. Also, I trust that the dealer drained the lower unit as part of the winterization...so I certainly assume that it is not a cracked lower unit.
Any thoughts on this one? I'm assuming a seal. I also checked both the gearcase drain/fill plug and lube level plug and both were tightly secured.
walleyehed
Re: Another Oil Leak Question (BP North)
I've learned in the AViation industry the word "assume" will bust ya sooner or later. Yes, It should have been drained and changed. What is the color of the oil and has the eng oil level dropped at all?
You might also ask around in the suzuki forums....that's what this engine is with white paint.
