hardtailcfl
Thread starter- Joined
- Aug 13, 2009
- 22
Re: Another NO spark thread...1961 Kiekhaefer 800 FGS
Good to know about the prop!! I'm sure things will change a bit too once it's in the water under load.
So I got the ignition switch picked up and "attempted" the wiring lol
There are only 3 posts on the one I got and per Mercury it replaces what I have. I am a little confused on what should go where.
OLD SWITCH 4 POST
A - Red wire
B - White wire
C - Yellow wire from "switch"
I - Black wire
NEW SWITCH 3 POST
A - Red wire
B - White wire
S - ??? I put Black here
My question is where does the Yellow "switch" wire need to go. I touched it to the empty terminal on the ignition switch and the motor fired up. I touched it to the "S" terminal and motor fires up when turning key. Only problem is it won't shut off
Without the "switch" in the system it would not start. Can this be bypassed? If not, how does it hook up?
OLD SWITCH 4 POST
A - Red wire
B - White wire
I - Black wire
NEW SWITCH 3 POST
A - Red wire
B - White wire
