hardtailcfl
- Aug 13, 2009
- 22
I acquired this motor after it had been sitting for approx 15 years. By the looks of things it is safe to assume it was not winterized properly...
So after checking compression, changing impeller, and gear lube I tried to fire it yesterday....no go.
I am brand new to points style ignition systems but after some reading I think I have a decent grasp on how they work.
So using a spark tester first tested for spark at the plug wires...NO
Used the spark tester again at both coils and still nothing.
Took the distributor apart, cleaned and regapped the points to .006 according the Mercury manual. Filed down (gently) the rotor tips and contact points in the dist cap. Put it all back together and still nothing.
I know to test the coils with an Ohm meter but I can't seem to find how or what the readings should be.
So I THINK I've narrowed it down to either coils or condensors. Anything I'm missing?
Thanks in advance!!
Thanks in advance!!
