billywhizz
Thread starter- Joined
- Nov 22, 2007
- 174
Or is it part of the first one, I found this in the lower case right at the front next to the shift shaft, what is it this time?
there was a black rubber bush around the shaft but sitting outside on top of the impellar housing, is it supposed to be in the recess of the housing around the shaft? also the little chamber where the shift shaft is was completely full of crud, I cleaned it out and my question is,
the water wont drain out of the chamber so I poked about in the bottom with a thin welding rod it went in a few inches and stopped, should i poke harder? is the little drain hole down below to drain this chamber?
thanks for your help, Bill
