phwrd
Thread starter- Joined
- Jul 30, 2007
- 294
Installed a Flo Meter, new sending unit, all new lines for the fuel system. Racor water seperator, added a 10 micron filter, even a shut off valve. Bulb fills with fuel, the filters fill with fuel.
Then why won't the motor pick up fuel above idle off the internal (aluminum) fuel tank? Finally took it to a mechanic, Flow turbine is good, fuel gauge now works, filters are clean, gas is good. So why can't I get the motor to stay runnning.
He determined that the hose is either twisted, kinked or defective, between the meter and the filter. Longest run on the boat, 6 foot. Now have to take the boat apart again to replace a $20 piece of hose.
Run H2O or air thru hoses or tubes to make sure they are good before you install them....
Just another hard knocks lesson i would like pass on, maybe save someone else the pain . . .
