ScottieScott
Thread starter- Joined
- Nov 28, 2011
- 30
Hi all,
I have a 1986 Mercruiser 170 with an Alpha One Gen 1 outdrive. The last time we had it on the water was a couple of years ago, and we were getting water in the bilge, just sitting in the water, as well as when running.
Fast forward to this season.....I have changed the U-joint bellows, replaced the shift cable and bellows, and put on an exhaust tube. When I checked the old bellows that I removed, they were fine.
This season, I don't get any water in the bilge while running on a hose in the driveway. We took it out this weekend, and we get water again, either sitting, or driving. I am rather certain that the exhaust elbow is still in good shape as I don't see, feel, or hear any water coming into the bilge from there.
The amount of water seems to be a bit more while sitting, but it is a significant amount. I am going to guess that in the 2 hours we were out, we pumped several gallons, and when we pulled the plug when taking out, a couple more gallons came out.
I have checked and rechecked the bellows, the transom is solid, there are no cracks or compromises in the hull.
What other points do I need to check?
I have read where the trim hose manifold gasket might be an issue, and it seems to be filling from the bottom, if that makes sense. Is there anywhere else to check?
The steering cable exit is pretty high isn't it? I would think that this would be out of the water almost completely when running.....and we still get quite a bit of water when running.
Thanks in advance.
Scott
Thanks in advance.
Scott
