Another gauges don't work ;-(
briankay12
Although I've searched the posts I haven't been able to solve my problem and am hopeful someone may be able to shed some light. At the end of last season my gauges stopped working. I have checked and have power at the ignition switch and have negative 12volts at the gauges when the key is turned on. I'm not sure what this means. Is there a common relay or breaker that services the gauges? Thanks for the help.
Don S
Re: Another gauges don't work ;-(
What are we working on?
CoffeeHound
Sounds like reversed battery leads to me -- Never yet seen gauges other than an Amp. gauge that worked off of Neg. 12 volts and the Amp.gauge will work backwards . Great way to take out rectifier and stator on any boat motor !!
briankay12
I did figure that one out, had the leads reversed on the test meter (duh). The boat I'm working on is a cajun bass boat with a johnson 112 spl outboard. Seems to be power to the gauges ( speedo, tach, trim and fuel) but they don't work. Tach is pinned at 6000. thanks for the replies
briankay12
Ayuh,.... Seems,..?? Is that a Yes, they're powered,..??
What about the Ground side,..??
briankay12
Not sure what you mean. I assume that if I put a tester probe on the + wire and the other on the ground and it shows 12volts that the ground is good. am I wrong?
NYBo
Where is the ground you probed? Each gauge has a battery- terminal that must be hooked up for the gauge to work.
CoffeeHound
On my gauges -- the third wire goes to the sending units thru a cable from the gauges to the motor. Also all my gauges have 3 wires
Pos. 12vdc from switch --instrument lights only it looks like
neg. Ground that goes to the ground bar at the fuse block
Signal wire that goes in the cable back to the motor sending units
Have Fun !! .
briankay12
I'm using my fuel gauge for the testing since they all stopped working at the same time. at the panel I have 12volts on the positive and ground, same at the key switch. on the back of the gauge there are four wires, note: the light does work , I have 12 volts on the ground/sender (purple) wire and 9.85 volts on the red/ground.
briankay12
Here is a picture of the back of the fuel gauge. I'm using my fuel gauge for the testing since they all stopped working at the same time. at the panel I have 12volts on the positive and ground, same at the key switch. on the back of the gauge there are four wires, note: the light does work , I have 12 volts on the ground/sender (purple) wire and 9.85 volts on the red/ground.
Silvertip
Honorary Supreme Mariner
Look at this diagram carefully. Note how the gauges SHOULD be wired. This is called "daisy chaining". If each gauge in the string does not have +12 volts on the "I" terminal, and the ground terminal is not grounded, and the sender "S" terminal is not connected to the sender or the sender is bad, then the associated gauges will not work. You keep saying things like "I have 12 volts on the ground/sender wire and 9.85 on the red/ground. YOu cannot have +12 volts or any other voltage on a ground wire. If your boat has a "voltmeter" on the console and it is not working the answer to your problem is obvious. +12 volts and ground are missing because that's all it takes to operate a voltmeter. And why is there a red wire on the ground terminal?
briankay12
when i say i have 12 volts on the ground/sender, I mean that the red probe on my tester is on the sender wire and the black is on my ground. Isn't this how you test a wire? My wiring does follow the diagram, All my gauges have always worked fine then stopped. No wires have ever been switched or moved so I am assuming that everything is wired correctly and I just have a blown fuse or resistor. I don't have a volt meter on the console. Is there a common sender unit that they all run through or does each unit have it's own?
Ayuh,... It sounds like yer using a multimeter....
Meter the Grounds at the dash, to the Battery's (-) terminal....
You should see little to No resistance....
Or,...
Jumper another wire from the battery's (-) to the gauge's Ground....
Silvertip
If your gauges are indeed wired like the diagram but you are using only the ground on the fuel gauge for testing purposes, you are not proving each gauge has a ground. You are proving each gauge has +12 volts but unless you move the negative probe to the ground terminal on each gauge you have not proved ground is good on the gauge under test. Look at it this way, assume the ground wire is physically removed from any other gauge but the +12 volt wire is indeed in place. If y0u have the negative probe of the meter on the fuel gauge ground and the positive probe on the gauge you are testing, you would actually measure +12 volts. But the gauge won't work because the ground is obviously missing. The meter works because it is actually on a good ground. If you put the negative probe on the gauge with the missing ground wire it would not read +12 volts because there is not ground..
Think hard about why a voltmeter does or does not need a sender. You are using a meter to measure voltage in your boat are you not?. Does the meter need a sender to do that? Of course not. A voltmeter needs only +12 volts and ground to measure electrical system voltage. The gauge will have a third wire for the internal light if it has one. If you look at the diagram you can see there is no sender connection on a voltmeter -- or the speedometer (but there is a pitot tube for the speedometer)..
briankay12
I do have good ground all around. If you look at my gauge I have 12 volts on the purple wire which i assume is a switched feed to the fuel gauge. at the red wire i have 9.85 volts. would anyone be able to enlighten me as to where this red wire goes and how it works. I'm still trying to find a common factor ( i have ruled out bad ground) to all my gauges failing at the same time. Thanks in advance
Silvertip
You have definitely NOT ruled out a bad ground as the cause of the gauges not working. You have also NOT proven you have +12 volts on ALL gauges. To lose ALL gauges at once means you either lost +12 votls or ground or both. You test a wire with an ohm meter. You test for the presense of voltage with a voltmeter.
Look carefully at the back of the gauge next to each terminal. Now list what each terminal is labeled and the color of the wire on each terminal. Your picture is too fuzzy and we can't see the markings. The markings should be as follows -- so add the wire colors to that list.:
L = Light (switched by the NAV/ANCOR switch)
I = Ignition (=12 votls with key on) wire should come from the "A" (accessory terminal on the ignition switch)
S = Sender (comes from the applicable sender) -- fuel, trim, temp, etc
Ground symbol = ground
