mt3
- Aug 21, 2008
- 25
i have read and tried all things from all the other posts .... here is where i am ...
1. Motor moves freely with the "steering arm thing" disconnected
2. Loosened nut on starboard side of motor ... wheel will now turn and shaft moves in and out of the tube several inches.
3. drenched everything i could with PB blaster and some other free-up lube from the marine store.
.... but arm on port side still will not budge in to out ... will rotate when i twist from other side ... it is mostly out of the tube ....
tried banging on it with rubber mallet, but only 6 inches between end and side of transom ....
PLEASE!!! ..... any further suggestions would be very very appreciated ....
Do i need to loosen nut on port side of tilt tube?
THANK YOU in advanced
1990 135HP Mercury
1990 135HP Mercury
