another Force ?
puller45
I know this has probably been asked before, but I am unable to find a specific answer. What lower units will fit on my force 85 HP (1984). It is 20" and the Model # is 856X4L. Can anyone turn me on to a possible supplier of a used unit or Parts. I'm not sure how bad it is I haven't been able to coax the shafts out of it an do not have a manual yet.
Found one one ebay, thanks.
jerryjerry05
Re: another Force ?
The 20" shaft was used on a bunch of stuff.
I believe it was started in 1980(not positive) and used till 1989 then they brought out the 2 piece shaft.
The 20 from a 125 will fit too.You just need check the rpm's and maybe change the prop?
Why are you working on it?
E-bay sells used stuff. Just make sure the stuff matches.
There are a lot of dealers who sell remans.
