First off this forum is amazing and the people here are fantastic for helping others........
Restoring a lil 16 footer (not sure of make) with 55HP Johnson and this one needed the whole works; transom, stringers, floor and redesigned front casting deck. Having a blast doing it and spen around 2-3 hours nightly on here reading and trying to take in all the info.
I have searched all over but cant seem to get answer
1.) could I lay the floor in while the poly resin is still wet (underside) on top of the stringers or should I let if cure up and then just lay in with PL adhesive?
2.) Once transom is in place and I drill out the holes for the transom plate I am guessing that I seal with more poly resin (inside holes) but was curious that if there is any movement on the bolts would that crack resin on edges of wood so should I apply any other sealant (dont want to do all this work only to have bolt movement ruin seal.)
Thanks in advance for the help/info.....
