I have a 16' mid 70's Mark Twain fiberglass tri-hull with same year Merc 115 which I approx. the weight on water at 2000 - 2500 pounds with 4 adult riders. I'm looking a mid 70's 16' aluminum Starcraft open bow v hull with same year Evinrude 50 hp which I'm guessing would weight 1000 - 1500 with 4 riders. Even if my weights are off I think the Aluminum would weight at least 1000 pounds less. Would the lighter boat with smaller engine pull a adult tuber/ skiier similar - better - worse than the fiberglass tri-hull? Reason for the possible switch is its a ***** to pull the fiberglass boat out of the water at my ramp on my property even with my 4x4.
