Re: another charging issue......
Bo
not trying to diminish the info on the other topics & batteries in general.<br /> but if you charge your batteries and you run your boat, and you feel like the batteries are lasting all day, then don't worry about it- use one charger to do the job, a 10amp charger will handle 2 batteries in @ 4hrs pretty fine. best is a slower charge, like a trickle charger (2amp) for 12hrs...<br /><br />to be more stewardly on your battery levels, just goto walmart and get an elcheapo($10) voltmeter and verify the batteries are reaching 12.6v total. you should get an average since they're in parallel, and they are (each)6cells X 2.1v ea [when charged]<br /><br />to avoid overcharging is by not leaving them charging for 2days, or observing 'boiling over' type discharge from the vents, or bulging of the sides - you know, like when your hotdog is over nuked in the microwave - overcharging usually ends up overheating and boiling/drying out the cells. don't sweat it unless you leav'em charging on something bigger than a 2amp charger for over 24hrs.<br /><br />just my 2c worth
