I have began the process of dismantling my carbs. While inspecting one of them I noticed the by pass tube tip (bottom) looks
bent or smashed. How do I remove the tube ? Its the one that goes through middle of carb chamber towards float. If the tip is
bent or closed what effect will this have ? Should I replace ? This is also the lower carb that had been leaking.
Thanks again
Thanks again
