Another boiling battery...
doggies3
Another problem with my '89 Force 125 H.P. - I have dual batteries in my bass boat and have them switched so that I can charge one or both at once. I tried to charge both while making a long lake run (rather than using the charger at home) and I think I sucked too many amps through something - my amp meter is pegged at about 18 volts and the batteries are boiling. Lot's of hydrogen gas back there - I think I'm going to blow up! One parts dealer told me there is no regulator, that I blew the rectifier? I ordered one but haven't received it yet. Sound right?
OBJ
Re: Another boiling battery...
Dave....go back to the list and scroll down till you see "boiling battery" Some good info on that thread.<br /><br />OBJim :D
rons boat
Many rectifiers are blown by swithing batteries while motor runinng due to fact that Mercury uses diodes that have a low Peak Inverse Rating in the bridge rectifier assembly. The tiniest spark will do it in. Save the old one, get the potting material out and you will see how physically small they are. A largerer bridge rectifier which is not available from the manufacturer could be constructed if you are handy with electronics. A .01uf capacitor across the output of your new rectifier may help to prevent transient voltages from doing to you what has all ready happened once, but the PIV is not high enough and it probably will happen again. The parts to make a new heavy duty bridge rectifier cost less than ten dollars, but I don't know anyone manufacturing them. A very good do it yourself project. Meanwhile, install the capacitor and don't do any switches with the motor running and tighten all connections with lockwashers. Also make sure all batteries that fail in your installation short out instead of going open. Ha, Why, because violation of any one of these rules produce short high voltages which pop these low rated rectifiers like corks.
