Another bad gimbal bearing, brown lube all over in billows?
esanford
Hi all! At the end of last season I started to hear some grinding from my Alpha. I pulled off the outdrive, and it looks like a bad gimbal bearing. The bearing turns rough in my fingers. It bought the boat a year ago and it had a bad bearing then. I bought the alignment tool and adjusted the front of the motor about a half inch after replacing THAT bearing, and all was well all summer. I figured the alignment was going to be off this time too, but the tool slides in and out like butter in the current (bad) bearing. The inside of the bellows is also filled with brown oil. I assumed it was gearlube, but could it be grease from the bearing? Seems like way too much. It doesn't smell as awful as fresh lube, though- I couldn't tell for sure what it was. I unscrewed the plugs from the top and bottom of the drive, and there's clean lube in both ends, no water out the bottom. This was after sitting over winter. The level of the lube is maybe three inches below the vent hole. As for the U joints, they appear tight, they don't wiggle in any direction they're not supposed to by hand.
So, any ideas why my new-last-spring gimbal bearing went out, even though the engine appears aligned? Could be just a defective one. Bad U joints? How do I check those properly? Also, where's all that brown oil from? Splashing gearlube out a bad shaft seal? Do I need to somehow check shaft bearings for wear, could that be what caused the gimbal bearing to go?
Any ideas are appreciated!!
-Eric
Bt Doctur
Re: Another bad gimbal bearing, brown lube all over in billows?
3 inches down from the vent means that oil went someplace.My guess is the carrier seal and into the bellows.
achris
More fish than mountain goat
Brown lube = gear oil + water.... And that's why you lost the new gimbal bearing. Somewhere water is getting in....
Grub54891
Wow,3 inches low,lucky the upper didn't blow out! I'd drain the unit,pressure check it and find out where the leak is,like stated already up top the driveshaft seal is more than likely bad but,don't rule out any other seals when checking over.
Grub
mercs4mark
Like Chris said you have two problems .....where is the water entering the bellows?
