another anchoring questione
Silver Eagle
Master Chief Petty Officer
Your cruisin up the bay when you see a spot that you want to anchor in along the shore. Now do you come in and first drop the rear anchor ,or do you drop the front anchor and shut the the motor off and swing around on it.then throw the rear anchor out.? And what do you do if there are boats near by.?
EGlideRider
Re: another anchoring questione
Never drop the rear anchor first unless you are in very calm waters and wind.
If you are wanting to position your boat parallel then approach the shore into the wind or current, whichever is strongest. Drop the bow anchor and pay out the proper scope (7 feet per 1 foot of depth). When the bow anchor is set then throw the stern anchor as far as possible if you are parallel to the shore. If not, throw the stern anchor toward shore and pull the stern toward shore.
If the wind is nearly perpendicular to the shore, then make a perpendicular approach to the shore and drop and set the bow anchor as above. Then use a little reverse power to bring the stern toward the shore then throw the stern anchor.
When leaving, retreive the stern anchor first.
