trumanlake
Thread starter- Joined
- Aug 8, 2003
- 131
We purchased a 93' Wellcraft w/5.7 Mercruiser Alpha 1 Gen II last year. Pulled the drive (no problem at all with removing, slid right out) over the winter to check things over and to replace impeller. Ordered alignment tool, and found the alignment off ever so slightly. Takes a little nudge to get the tool to go all the way in. The grease marks are much deeper on the top than the bottom. Have also checked at 90 deg intervals, no change. Have raised and lowered front mounts, and that has not changed the ease of insertion of the tool. Have mic'd the tool and it is right on the money. Crawled down in the bilge to get an eyeball on the rear mounts, neither are down on the fiber washer. But I did notice that the starboard mount looked different than the port when viewed from the side. Attached drawing simulates what I was seeing. The starboard mount (tang on transom plate and tang on engine bell housing) just wasn't parallel as the port side is. I guess my question would be, if the front mounts are not loaded evenly what kind of problem would you expect to see, and how would you check to see if the engine is being lifted higher on one side and not the other? Puzzled on this one.
