Hi Guys,<br />Im new to the forum and iv went through all the 85/125 force problems that are similar to mine but have not seen any post of people resolving this problem so I just wanted to get some thoughts.<br /><br />let me give you a little history on it first:<br />At the time of buying the boat from my boss it ran ok at idle and lower RPMS but would not hit top end. After a carb rebuild, new water pump, new fuel lines, filter, water seperator, impeller, exhaust boot, plugs, timing and reg maintenence. It ran great till the end of the summer. Then one day it would be fine for the first 10 mins and then would not open all the way w/o bogging down. After 3 carb rebuilds I finally found a pinhole in the bottom float. It now has the new float in and ran great for a few months.<br /><br />Now Im having a problem that I dont think is fuel problem. When I give it WOT it jumps up and you can hear it sound normal and then just before it plains it loses some power. it still runs good but its not getting full power. I can throttle back down and do it again and it will do the same thing. Iv had someone pump the primer bulb just to see but no worky. I also changed plugs, changed out a spark plug lead, cleaned all the contacts but none have worked. Compression is good, timing is good and everthing else seems to be functioning fine. Im outta ideas now.<br /><br />Thanks for any help guys!
