Another 15 OMC starting problem
thatone123
Banned
This one is more complicated in the fact that the motor was dumped along with an airplane in a glacial river in Alaska. The whole motor was full of fine glacial silt. Motor has been cleaned twice and engine still has good compression over 100. Replaced everything under the flywheel and the cdi and coils are good and has great spark, but floods very easy and hard to start because of this. Will run if I keep it revved up, but will die if I let it just run. A lot of that unburned yellow grey unburnt oil in the test water barrel. This is a later model (late 80'/early-mid 90's., the last model of this engine, with the mexico plastic top carb. My next ploy is to clean the carb for the 2nd time. How many turns out for the idle screw? I am sure it is more than the old standard 1 1/2 but maybe I am wrong.
175se
Maybe time to clean the card, esp if its the one with that (neoprene?) idle tube.
AlTn
try 4 turns out...if this is a motor that has the idle speed adjustment at the end of the throttle handle, it requires some adjusting of both at the same time to achieve a good low speed idle that won't die when you come back to idle from higher rpm's or a faster trolling speed than just idle
flyingscott
If you have the knob at the end of the tiller that is not the idle adjustment. That is a throttle lock for trolling. 1.5 turns will get you started. The idle adjustment is either under the flywheel or the cable itself needs to be adjusted.
thatone123
Banned
Model is J15REUC.....idle adjustment under the flywheel? Never have seen this? Will try 4 turns out. Neoprene idle tube? That must be that little black plastic thing on the side, always wondered that that was? lol Hate to take the flywheel off again, but will if an idle adjustment is under there. Or do you mean that black plastic throttle plate cam that fits in the 2 holes that is wedged between the 2 brass plates.
thatone123
Banned
Yes, I followed up on all the ideas above and I get it now, I should have known, about the cam,(in effect, yes, under the flywheel, but thought of by me at least as under the throttle plate/stator.) throttle arm and cable adjustment in the back. Seems all of them work kind of in sync, jut never had to pay much attention to them in low time motors. I think maybe that fine talcum power like dust may still be lurking in the main jet or somewhere though. The stuff packs in like concrete in any kind of indentation, hole, or what have you.
Honorary Supreme Mariner
So have you had this motor all apart to clean the insides or just an external wash and then a " crank and hope " approach to start it.----The oil return passage way may be plugged with silt for one thing !!----Bearings may be loaded up with sand as well.
thatone123
Banned
racer, yes, you are probably right, but, the folks I got it from of someone did take off the intake manifold and must have did a basic carb clean. It looks like they did not do a through job of cleaning and there may be grit in the bearings. I feel they probably knew this and got as much out as possible. It runs good and good compression, so I am hoping it will be ok. If any outboard can make it these can as you know they are tough. I have worked on a number of them that logic sez should not run, but do. Hoping the oil passage will not be clogged, just have to wait and see. I have another one I have posted about and was thinking of rebuilding, but am giving up in it and just cannibalizing it for parts. That one was a salt water night mare and no compression in the rings.
AlTn
Flyingscott is correct ..the knob on the end of the throttle cable is for setting a higher trolling speed or higher speed for whatever reason...the idle speed is adjusted by shortening or lengthening the cable using a plastic ball that is captured under a small plate in the lower pan...you'll see the plate as it is adjacent to a rubber mount in the pan on the tiller handle side...one screw holds the plate on, remove it and the plate and you'll see the ball with the threaded part of the cable going through it..rotating the ball cw or ccw adjust the cable length thus slightly increasing or decreasing the idle speed.....turn the knob on the throttle handle fully ccw before adjusting the idle speed with the plastic ball
AITn-----Are you sure you are describing the set-up on a 1997 model ??
AlTn
No..this is for an early "90's...not certain it carries over for a '97
thatone123
Banned
Yes, I have seen that on the 90's, but don't think it carried over to this one. in fact the end of the shifter is left open like they just deleted this feature. Anyway, I don't think it is that. I cleaned the carb full out in a hydrosonic cleaner and etc. It was amazing the fine silt that came out of the carb. I took off the aluminum cap on the top of the jet post. It is indented into the top of the post and smaller than most standard caps on the 74 to 80's models and lots of OMC small outboards. I drove it in best as I could. I got the motor to run well ( for a while) it as idling good and etc., then just started acting up and died. Really confusing and I'm experienced at this. It would start again at high RMP only and sputter loudly and die. Took apart the carb again as I thought it might be that small aluminum cap came loose, but it seemed ok and did not leak air when I blew thru it. The only thing I can think of now is wait til I come across a new carb. I also have a 9.9 carb for this engine and I think I will clean the carb and install it on this motor just to see if it will run proper and go from there.
thatone123
Banned
OK....So I happened to have a spare 15 carb that I cleaned and pun on the motor...Same exact problem of will start at high rpm, but not stay running. This tells me it is not the carb as I have suspected. The former owner took off the intake manifold and I am wondering if they screwed up the reeds somehow? On the schematic for this motor at the parts house, it does not show a intake manifold or reeds?
AlTn
welp..gotta have one..just google your model no. then.. intake manifold parts diagram
thatone123
Banned
Know it's gotta have one, wondering why they don't show it, anyway, tool another 15 manifold off and on this one the reeds are rusted, so maybe this one has similar problem. Hate to bother taking it off as it is kind of a pain, but don't know what else to do?
thatone123
Banned
Ok... I have changed 3 different carbs. and no change except I have found that the bottom plug is getting oily and that is why it was not staying running for long and hard to keep started and running. The compression is 90 in both cylinders. IT runs but shutters and runs not good. If a ring is sticking would not the compression be different or not? I know there is a depth of experience here and I have never experienced ring sticking, broke rings that I know of.
