anode won't come off
donke
I have a 1988 evenrude 100 on a proline. I am trying to get off the anode on the lower motor mount bolts but they won't budge. My question is are the anodes threaded and come off counter clockwise or something else. I'm afraid to apply too much torque and bust the bolt. attched is a picture of the problem child.
thanks
pn
Re: anode won't come off
is there a reason why your taking the annode off? It looks like there is alot of meat there to do the job that it is there for, just leave it. If your changing the motor out and you bust the bolt then change the bolt out when you put the new motor on. Threaded, heat, pipe wrench ccw.
donke
I'm installing a power pole via an adapter between the motor mount and transom. I eventually got them off with a butane torch, hammer, wd40, and pipe vise grips. They are threaded and I can reuse. thanks for the replies.
