I have a 1972 165 hp l6 250 ci mercruiser with a pre alpha outdrive. It is raw water cooled. Should I have some kind of "pee hole"? I see the water go in but I see no where that the water is coming out besides a little in the exhaust. I have a coonection on the side of the block for hooking a hose up to, if I open this connection hot water definately comes out at about the rate of a gallon a minute. Should I hook this up to a bilge port so my hot water has an outlet or is there supposed to be a vent somewhere else?
